Repacking stuffing box
WJA302
Jul 18, 2009
16
Catalina 27 Middle River, Maryland
Hello, Another new owner question. (Thanks to all who helped with replacing the anchor light & bosun's chair info - that was fun - not!).
Today I had a marine electrician tell me he noticed about one drip per/5 sec. comming out of my stuffing box and that is too fast. (motor was not running)
I recently purchased the boat ('87 Cat 27 w M18 Universal engine). The former owner gave me a vast supply of parts/hardware which included stuffing material. He told me that "every once in a while you just need to add a little more stuffing around the shaft". I checked the archives and there is not a whole lot of info out there. I don't mind getting my hands dirty but I don't want to burn up something. In this just a matter of backing off a housing nut and adding packing? Should I tear out the remaining old stuff and replace everything? The boat is in the water but I'll be pulling it in a few weeks - should I do this on the hard? I want to learn to do things myself but I don't mind calling a mechanic if there is a significant risk of doing major damage. Thanks.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Before you remove the old packing, (always a good idea) buy a packing removal tool. It looks like a skinny corkscrew with a "T" handle, and makes the job much easier!
Not necessarily
Many people suggest this tool. I bought one and it did NOT work for me because with our 1 inch shaft and 3/16 inch packing there was simply NO room for the tool, which looks like a twisted pig's tail. For some it works. My referenced article recommend a dry wall screw for extracting the the old packing.
Before you spend the $$ on the tool, find some screws at your ACE hardware store, and/or back off the lock nut, move up the stuffing gland nut and see what kinda clearance you actually have there on YOUR boat.
WJA302
Jul 18, 2009
16
Thanks
Thanks for the info, that was a great link. I am learning that you need to be a contortionist to work on boats. When I started to work on this I immediately noted that both nuts were little more than finger tight. I made less than a 1/4 turn on each and the drip reduced to about 1 every minute or more. I decided to live with that now since a check valve blew when I turned my water pump on and I needed to work on that.
I also replaced the joker valve on the head system learned a little more about how my system works. I am getting my wish about learning boat systems and at some point I may even get to SAIL!!!!!
Thanks again, WJA
Aug 3, 2009
109
Catalina 30 great neck, ny
I drip per minute? I was told that it should be 1 drip every few seconds. Maybe that's way my batteries are dead from overworking the bilge pump.
