I just repacked the stuffing box on my O'Day 32' CC with GFO. I wasn't sure which size, 3/16" or 1/4", so I ordered both, as the boat is about 2 hours away, and I had only one day to drive there, clean out the old packing and clean up the fitting, and repack. She's on the hard now, scheduled to be put over the side later this week. I compared the old flax packing with both the 3/16 and 1/4, and it was a close call, but the 3/16 seemed like the right one. After installing 3 very carefully-cut rings, I test fitted the adjusting cap, but hand tightening gently (yes, I read the instructions), the adjuster went so far on that there were very few threads left to use the locknut, let alone adjust after the 2-3 hour break-in run. I added two more rings, and it seemed just about right. Do you guys think this will be ok, or should I redo using the 1/4"?
