repacking rudder shaft
64
Catalina 30 Ruskin/Tampa Bay
I am repacking my rudder shaft. After removing the old packing I purchased 5/16 GFO packing. 1 ring fits pefectly with not much if anything to compress once the top metal ring is bolted down. is that correct? If I put in a second ring it will not be in the channel. looking for help. The boat is a 1984 C-30 SRFK
Ron
Chels-A-Bella
Warwick,RI
5/16 is WAY too big, get it OUT NOW
or you'll score your shaft!!!
Use either 3/16, which most use, or 1/4, which RARELY is correct for your boat or any C34s or C36s, but some, a very few have reported that it works for them.
Feb 6, 1998
11,772
Rudder..
Stu,
Are you aware he's talking about a rudder shaft not a prop shaft? My C-36 rudder took 5/16 IIRC..
Jun 2, 2004
64
Results
I have received info from Catalina yachts that the rudder shaft stuffing box on my '84 C-30 calls for one ring of 5/16 packing:D
Ron
Chels-A-Bella
Feb 6, 1998
11,772
Ron
Chels-A-Bella
Sorry for the bad info on number of rings. It must have been my old Cape Dory that took three or four not my C-36. I just dug through some old photos of the C-36 and now I remember that stuffing box and it definitely only took one ring.
