Reomoval of Stickers
SHADS
Apr 8, 2007
67
Hunter 26 Winnipeg, Canada
The previous owners of our boat had put slip stickers on the side of the hull. there are several of them. I've tried different things to try and remove them with no luck. Someone said try easy-off oven cleaner. This seems kind of harsh. Has anyone had this problem? what did you use?
paphman
Goof-Off
Get a product called Goof-Off. You can get it at any paint store or Lowes. It is the best stuff you will ever use to remove stickers, bedding compound etc. Dale
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Heat gun
Have you tried a heat gun. We took off 20 year old pin stripes with little problems. Lettering came off in a snap also. Not too hot though as you could damage the gell coat........... Good Luck! Greg
Dec 16, 2006
23
Hunter Legend 35 Gresham, OR
Eraser Wheel
Any decent auto parts store should have them. You chuck it in an electric drill and run the rubber wheel over the decal. It removes them quickly and won't damage the finish. A great tool. Randy
Apr 11, 2006
60
- - corpus christi, tx
heat gun
first, gently heat it up and peel it off. Does not have to get too hot either. Seems like less trouble than solvents, quicker and cleaner. Heat Gun = Harbor Freight 10 Bucks.
