I have a Legend 35.5 and need to replace the plastic thru-hull fitting for my bilge pump outlet (above the waterline) due to a hellacious winter storm which scraped it off against the dock. Amazingly, that's the only damage I need to deal with. I'm very nervous about getting this done, at present I believe any significant bilge pump discharge will pull it loose and dump everything into the boat. I've poked and prodded and I believe the fitting is located behind the shower wall, I can't believe I actually have to remove the wall to get to it? Does anyone have any experience with this? I loosened the shower nozzle fittings to try and get a peek, but can't even get enough room under it to take a look, let alone attempt any work through this 2" hole, which has hoses hooked to it of course. After reading about cutting a hole for replacing the waste tank, I guess it doesn't surprise me. Maybe I'm better off cutting a hole, although it's not a flat surface? Removing the wall doesn't LOOK like it would be too difficult, but that's often a different story after you get into it. Any advice is appreciated!
