Hello everyone. I am planning to remove the mast on my S2 9.2 C , in order to repair a rotten support of the compression post. What do I have to pay attention to when I do that? The mast support has four bolts the go from the top to the inside through the compression post. Do I need to pry the bottom of the mast in order to detach it or the crane will simply lift it once the bolts are loose and the shrouds and stays removed. Thanks for any advise
