removing stripping
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
a wall paper steamer and razor scraper worked well for me.
Dec 2, 1999
15,184
If the vinyl is thin and cracked the "eraser" works well.
If the vinyl is still plyable the wall paper streamer work great. I never had any luck with heat guns/hair dryers.
-na -NA Anywhere USA
Dion is doing what I did as a dealer. Use of a thin blade scraper will marr the gel coat if you figit as I would call.
Oct 14, 2013
20
Hunter 22 Gulf Shores Alabama
I just asked this same question a few weeks ago. I started using a paint scraper and a heat-gun....now that sounds bad but listen. I directed the heat gun primarily at the scraper. This really heated up the scraper, then the hot air flowed down the blade to the pin striping and heated it up as well. The hot scraper slid easily through the striping. It came off nicely then I washed it down with that goop like remover from Walmart. It worked pretty good without any blistering. Just took my time over several days.
Feb 6, 1998
11,709
3M Stripe-Off wheel hands down..... Faster, easier and less potential to marr or damage the gel coat...
