A
Alan Gearing
My survey revealed some deck moisture problems, the suggested solution to which was to remove the deck fittings in the problem areas and let the area dry out over the winter. Anybody got any suggestions how to remove the stanchions, which are practically impossible to get at? Or, failing that, any alternative suggestions, such as how to seal fittings to prevent moisture problems getting worse?Any advice would be greatly appreciated.
