Removing Stains From Interior Teak
May 17, 2014
136
hunter 380 Plano, TX
So with all the rain this season and especially the amounts we received, I had a few small leaks around hatches that became a problem. Some of these have stained the teak inside my Hunter 380. I was going to use the vinegar and olive oil to get some of the stains out but decided to check in first and see if anybody has had to do this and what the best remedy is short of refinishing.
Thanks in advance for your responses,
Jan 6, 2010
1,520
P,
Do you have varnished or oiled wood?
Mine is varnished so, I don't usually have stains from water. I assume you have oiled wood. Some folks I know that use oil just use bleach & then rinse with water.
CR
