Hey all,
Solo sailor here working on my 1981 Hunter Cherubini 30. I'm trying to remove a Raymarine ST4000+ wheel pilot from my Edson Destroyer-style wheel, and I’ve hit a bit of a wall. I figured I'd post in case anyone else has done this dance before and can save me from breaking something expensive.
So far, I’ve removed a few of the obvious nuts and screws from the gray drive ring. But it looks like I’ve hit the point where I need to actually remove the wheel itself to fully slide the autopilot off. That’s where I’m stuck.
The center of the wheel hub has a circular metal cap—looks flush and has a little circle imprint in the middle. At first I thought I needed a special tool to poke in there, but after poking around online, I’m starting to think it’s just a decorative press-fit dust cap. Can anyone confirm?
If so, what’s the safest way to pry that cap off without damaging the stainless or surrounding material? I don’t want to scratch anything or deform the cap permanently.
Assuming I get that off, I’m guessing there’s a big nut underneath holding the wheel to the shaft. Anyone know what size that nut usually is? I’ve got a full socket set and an adjustable, just want to be prepared. Any issues with pulling the wheel off the taper? Should I hit it with penetrating oil beforehand?
Also curious if there's anything I need to be careful about when reinstalling later—like alignment with the drive unit or sensor. I know Raymarine units can be fussy about calibration.
Appreciate any insights. Trying to get the autopilot either fixed or removed entirely—right now it’s acting flaky and I suspect the clutch ring or internals are worn out.
Thanks in advance—cheers from the cockpit.
