Robert F
For a Beneteau First 32 vintage 1984. I am trying to change the stuffing box and to do so requires removing the prop shaft from the engine. There is a split collar surrounding the shaft at the point of attachment with the engine. Two big bolts on either side of the collar which compress it arund the shaft have been removed, and the collar opened a bit, but the shaft still wont come free. There is no obvious set screw on the collar or anyplace else, but there is a hole located on the collar but again with no apparent screw or pin meant to hold the shaft in place. Anyone know the secret to removing the shaft? With the bolts out and the collar loose I thought it would just come free but no luck. All suggestions appreciated!!
