Removing paint on hull
set2sail
Hello,
I need help.
I need to remove the "old boats name which is painted onto the hull.
Are there any specific products for this which won't damage the gelcoat?
dDo I need to scrape etc.
Any and all hep is appreciated.
Rgds
Michel
~~~_/)~~~
Tom L
Jun 24, 2004
56
Hunter 23.5 & 29.5 Baltimore, MD
I just stripped paint from the topside gelcoat of my Hunter 23.5. I think the paint was Interlux. I used Interlux Interstrip 299E and a rounded (worn) putty knife (2in blade). This is recommended by Interlux and I found it worked well. I also used ZipStrip paint stripper gel which worked about as well as the Interlux except that it contains MEK and would soften the gelcoat if left on very long. I had to be very careful with the ZipStrip to not scratch or gouge the gelcoat. The Interstrip was not as hard on the gelcoat but I still had to be careful. Both softened the paint as well as the other.
The link given in the previous post sounds very knowledgable and I would try those methods first.
JoeD
Aug 31, 2005
116
Columbia 34 MKII Smith Point,VA
Name removal
I used Easy Off Oven Cleaner. It is very fast and leaves no marks. need to neturalize with vinegar. It is an Acid but very mild. Spray on let set till you see paint blister and wipe off. maybe three or four minutes at best.
Use very little it works very fast and is very cheap.
Good luck.
Jul 8, 2004
155
Hunter 33.5 Portsmouth VA
Ditto on the Easy Off
Easy Off worked when we removed the boat name on our first boat. If your going to rename the boat, be sure to do a renaming ceremony and invite your boating friends. It may be good insurance and it's definitely a good excuse to have a little dockside party!
Feb 6, 2007
1
- - Lake Hartwell, SC
I tried citra-strip, easy off, acetone, mineral spirits, soft scrub, green scotchguard scrubbies- it took all of these! It was very easy to scratch the gel coat, and I was so frustrated I didn't care- The vinyl letters covered up some of my over zealous scraping. It took me several hours of hard work and scrubbing.
Sep 27, 2008
80
Grampian 26 26 Penetang,Ontario
First tried to use Interstrip to remove 2 coats of paint and a layer of anti fouling paint. This method works if you have lots of time on your hands and a big budget to keep purchasing stripper.Used 2 litres of Interstrip to remove about 1/3 of the paint from a 19' hull. Took the scraper to the rest, sharp, and sanded with 100 grit with an air operated orbital sander in less time than the stripper. Primed and put on 2 coats of polyurethane paint. No antifouling required as I will be trailer sailing.
Dec 2, 1999
15,184
Michel:
I have always used Oven Off with great success. It sometimes takes two applications, but will remove 99% of the lettering. I had not heard about the vinegar, but that seems like a good idea.
