Removing old registration numbers and names
15
S2 7.9 Alexandria, VA
Any ideas on how to get the old registration number and the old name off my new (old) boat? I tried using a razor blade, but it is scratching the gelcoat. I've heard that WD-40 works--or maybe something like Goo Gone?
There is no electricity near the boat, so a heat gun is not an immediate option.
Thanks,
Bruce Baker
Falls Church, VA
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Thanks,
Bruce Baker
Falls Church, VA
I would find a way to make it an option, Bruce. An electric hair drier and a plastic putty knife will get it off. Then you can remove the glue with Goo-Gone.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Are the registration numbers vinyl stickers or painted on. BTW, there are new "plastic razor blades" that will take stickers and such off of fiberglass without scratching. If you have to use the metal ones, use some fine sandpaper and round the corners...so they don't dig in and scratch the gelcoat.
Jun 3, 2004
309
Prindle 18, beach catamaran Chicago (North Edgebrook), IL
I tried to clean off my old registration numbers when it was cold out, and it was very frustrating. A little heat made this job easy. If you can't get them warmed up, I would wait it out.
Cold they break apart and leave sticky goo.
Warm, they come off clean, in one piece.
37
Catalina 27 Old Saybrook
DB is right. In spite of what you are now thinking, there is no rush to remove the old numbers or name. Waiting for warmer weather and a longer extension cord for the heat gun will make your life a bunch easier. Think of another reason to have to go to the boat to fondle her. Leave the numberectomy for another time.
caguy
Sep 22, 2006
4,004
You might want to try MEK methyl ethyl ketone (nail polish remover). Melts plastic but doesn't seem to harm gel coat. Test it first. I have used it on mine to remove peer bumper marks.
Dan H
Oct 9, 2005
143
Catalina C25 SW Michigan
Test it first on the power boat over there, not on your boat :)
sloopy
Nov 22, 2008
16
Cape Dory 25 25 San Diego
Hair dryer
Even if I had to get an inverter to run my wife's hair dryer, or a 100' or 150' extension cord I'd use a hair dryer.
I've done this twice now and it's easy as all get out. I use a little Goof Off to get any residue off then apply the new letters, numbers, registration, whatever.
"You see a lot of foolish sailors and you see a lot of old sailors but you won't see any old foolish sailors."
sloopy
Cape Dory 25
San Diego Bay
biggio
Aug 12, 2007
87
Catalina 27 Mandeville, La.
I watch a guy detail the boat next to me. He used easy off oven cleaner to remove the boats old name. I believe the name was painted on.
Apr 12, 2005
263
Hunter 36 Cobb Island
It's bad luck to change a boat's name and hailing port. I hope you are planning a ceremony that will keep the wrath of Neptune at bay.
Jan 10, 2009
590
PDQ 32 Deale, MD
Also consider xylene - I think it did a bit better that the MEK, if only because it dried a bit more slowly. Safe on Imron too.
But the main point is to wait for warm weather - even a heat gun won';t warm the hull like the sun. I too am waiting to peal some numbers.
2,288
C30 Event Horizon Port Aransas
I'd rather my wife and I drown slowly than ask for neptune's blessing. If the blessing is not from Jesus, I don't want it.
Dec 9, 2006
694
Oday 22 Hickory, NC
Hermit Scott...just do what me and Dianne will do...substitute grape juice...like the Baptist do!
Agape
Jack-N-Dianne
2,288
I drink alcohol. I have no problem with that. I will not pay tribute to posidon in any way. I would literally rather die. I think dedication ceramonies are cool. People like those kinds of things and I think they are completely acceptable.
I think that people do things a lot of the time because everyone else is doing it, so it seems fine. For a non christian or athiest, a posidon ceramony is not a big deal.
I am not saying I am better than anyone else, just if you really believe something stick to it. One guy in the boat yard is convinced that posidon was coming to get him becasue he changed a name on a boat, even though he did the ritual. I was so shocked by his seriousness I couldn't even laugh.
Dec 9, 2006
694
Oday 22 Hickory, NC
Hermit Scott, I am also a Christain...and I think this denaming ritual is to be taken quite lightheartedly.
I don't think we will have to account for it at the Pearly Gates.
I did hear about one guy who didn't do the denaming...rotten luck...the Bahamian Ski Team Chearleadering team barded his boat, through all the clothes overboard and made him take them home to West End!
Jack
Apr 12, 2005
263
Hermit: Superstition is part of Sailings history, tradition and folklore. It's part of what makes us sailors. Otherwise you might as well be a power boater. Lighten up.
Oct 22, 2008
3,502
whether that is bad luck or not depends a lot on what the cheerleading team looks like..and whether they know how to sail, keep watch, varnish, etc. :). :)
Jack
2,288
I catch your sarcasm Jack, and indeed appriciate it. Yes indeed Dog, real bad luck would be the Jenny Craig cheer leading team boarding your boat throwing all their clothes over and sinking it. Leaving you with that image in your mind as you die.
I am not in an uproar or anything like that over it. But there is right and there is wrong, no in between. It reminds me of Shadrach not bowing down to worship the image Nebuchanezzar had built. Even though every one was doing it.
To some they would rather not take a chance on getting bad luck, so they do the ceramony. To me I would rather not do the ceramony in Posidon's name because I don't believe he's the one watching me while I am on the water.
This seems to be creeping toward a religious discussion, so I will post one last thing about this in this forum. If anyone would like to discuss it further, just tell me which place to go on SBO.
The whole truth of it is. I probably believe in Posidon more than any one else here. I believe there is a spiritual being that is Posidon. However I thinik this being is a demon or demons posing as a god, as with all other false gods. When you put your self under his/their authority, then you are subject to him. At least that is the way I understand it according to the bible. I have probably devoted more time to study religions and the bible more than any one subject. I didn't even believe there was a god until I was 19.
Someone told me the bible was the best selling book ever, and I wondered why.
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
I agree with Hermit. Christian belief and superstition don't mix. You either have faith, or you don't.
