removing M 18 starter and solenoid
dc3693
Jul 21, 2012
2
I need to remove the starter or at least the solenoid. What is the best to do this? The diagrams of the engine are not very good. Any tips? Should I remove the alternator and go thru thpe front, or go at it from behind ? Where is the solrnoid bolted on?
Oct 6, 2009
129
Newport Newport 28 MKII Jacksonville, FL
Get the alternator out of the way. I rewired my boat's wiring harness last fall and removing the alternator really opened things up in that area. Because it is a boat, you will probably end up having to go at it from the side, top, behind, underneath and front :) You may have to remove the oil filter to get at the bolts. Should be fairly easy, just take your time.
