I replaced all the laminate counter tops in my boat and it was well worth the time and money. First I removed the actual counter tops. Then I stood them on edge and used a metal scrapper and lots of acetone to seperate and remove the old laminate sheets. Sanded and vacumed. Then used contact cement and new laminate bought in sheets from Lowes. I used a router bought from harbor Freight with laminate cutting bit to do the edges. Did a few small pieces for practice but got good enough to do some really difficult cuts pretty quick. Let dry then re-installed on boat. Went from an almond color to bright white and it cleans up with a rag. I even put some laminate in parts of the cabin where it wasnt't before just because I had some left. It is so durable that it just doesn't mark up like paint or paneling does.
