Removing furling main - selden in mast furler
PKFK
Jul 12, 2004
206
Hunter 36 Ottawa
Hi - it's time to remove the mainsail for the season.
Unfortunately it's the first time doing so on this boat - and it has the selden in-mast furling system (hunter 36) - and I'm a bit stumped.
The problem is at the clew of the sail where the outhaul car has the outhaul line running thru a block in the clew of the sail, back along the boom, thru the boom, and back to the cockpit.
The only obvious way to de-rig this would be to undo the outhaul line from the cockpit back to the clew. This means I get to re-run the damn thing thru the boom in the spring - which seems silly.
I can't see how to undo it from the clew end of the sail because there is a spliced shackle on it, and therefore can't just undo that end from the sail due to the turning block installed in the sail. And I really don't want to pull the non-shackled end all the way out of the boom only to have re-feed it I the spring.
What am I missing here . :doh:
Thanks,
Paul
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
On my boat the shackle....
....can be undone and pulled out of the loop spliced in the end of the outhaul line. Then the outhaul line can be pulled out of the back end of the mainsail.
PKFK
Jul 12, 2004
206
Hunter 36 Ottawa
Ah - ok now I see what you mean. I didn't notice that the shackle can come out of the splice. Presto ! Thanks a lot.
This forum always is one of the best resources available.
Thanks again for the tip.
