Removing fuel pump on Atomic 4
35
Catalina 27 Rochester, NY
What are the steps for removing the non-electric fuel pump an the Atomic 4 engine (circu mid-70s)?
cat30
Jun 2, 2004
51
Island Packet 31 stony point,ny
atomic 4 list
you might want to join the atomic 4 list on sailnet.com - those guys know evrything.
Jun 3, 2004
71
Catalina 400 MkII Noank, CT
Very Easy to do...
Paul, From memory, you only have to remove the bolts that hold on the pump, and then remove the rod/pin that sticks out of the block. That rod/pin is what drives the mechanical pump. Once it is removed, a metal plate with a gasket is bolted on in place of the pump. Fuel fittings would then be reconfigured to go to an electric pump (I assume that's why you are asking).
