OOPS is right
When it was stil not completly cured, you could have removed it with acetone, but once it is cured I am affraid sanding is the only option...unless you can try to lift it up with a very sharp knife. If you deck was waxed, than there is a good chance that the epoxy didn't really stick to it .Hope this helps
