Removing cockpit coaming?
Apr 22, 2013
51
Catalina 22 Cincinnati
I have refinished all of my teak except the coamings. How do you remove these? Can't figure out how to do it.
Thanks
Jul 13, 2015
922
Catalina 22 #2552 2252 Kennewick, WA
It's going to depend on what they happen to be bedded with: but as a starter you might try some modest heat from a heat gun to help start the process -- light prying (Light! ) from a corner may reveal how much of what you might have to resort to- use a broad thin tool with as much surface area as possible: think 8" drywall knife.
When mine came off all four joints on both pieces essentially gave up-- but easily epoxied and repaired if necessary.
Joe
Jun 1, 2004
8,172
It's not worth it... tape off the non wood area and finish by hand.
Likes: Sacto Dave
Sep 14, 2014
1,278
Catalina 22 Pensacola, Florida
Dynamite, pool acid, sawsall, I agree tape it off and finish by hand, saves trying to repair it when it comes off in chunks.
Likes: Sacto Dave
Apr 22, 2013
51
Thanks guys. So sounds like it is put on with adhesive versus a faster? I assumed a faster then was baffled when I couldn't find one!
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
yes, adhesive. If you try to remove it, your next question will be to replace with synthetic vs. teak.
