Removing Cabin Headliner
Headliners are secured in place by velcro (rarely), screws (none showing), and glue (most likely).
Not an easy fix.
JamesG161
Feb 14, 2014
7,766
Hunter 430 Waveland, MS
Hunter does panels for Access, like in picture one.
You might ask Hunter by email.
Jim...
May 7, 2012
1,545
Hunter e33 Maple Bay, BC
It might be easier than you think...but not simple. There's a lot of videos around about removing some/all of the 2000-2010-ish headliners in Hunters, but here's one thread with a decent video and advice on the tool to use. Short answer is the headliner is probably pushed into a trac and can be removed if done carefully.
Replace Headliner Hunter 306 | Sailboat Owners Forums
Boy that will relieve a lot of stress. Knowing that the headliner is called Regal Headliner - Whisperwall is a huge step in solving the removal/install problem.
If a picture is worth a thousand words then the video in this thread is worth a million.
Likes: stuartsw
