removing bottom paint
Kenhup
Sep 15, 2013
5
Catalina 22 Lake Wallenpaupack
Can anyone suggest technique for removing bottom paint from a Catalina 22
It is currently poc-marked and blistered.
How do I remove this without harming gel coat
7,743
Alden 50 Sarasota, Florida
Your bigger concern should be how to repair the blisters.
Removing the paint can be done with remover chemicals, sanding or blasting.
Opening the blisters, drying the hull, fairing and replacing the removed gel will make the bottom paint removal inconsequential.
Dec 2, 1999
15,184
Take a look at Peel Away Marine.
After the paint is removed you may find that you really do not have blister in the gelcoat.
Ross
Jun 15, 2004
14,693
someone made enquiry to me about home formulated peel away equivalent. PM me if you want the details.
Feb 6, 2013
437
Hunter 31 Deale, MD
If you're at a marina you should check first to find out what the marina will allow. My marina gave few choices and I ended up sanding (dustless) off 9-10 coat of old bottom paint It was tedious, grueling work. I was pleased to find only one blister once all the paint was off.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
It took me 5.25 hr with a 5" random orbital sander to do my MacGregor 26D.
Try the stripper first.
