Removing Barnacles
485
Hunter 44 Mystic, Ct
Anyone have a tried and tested way to get barnacles off of a prop shaft? These are almost the size of golf balls and are the largest I have ever seen.
Jun 5, 2004
485
richk
Jan 24, 2007
495
Marlow-Hunter 37 Deep Creek off the Magothy River off ChesBay
try a drill with wire brush attachment (nm)
richk
Jan 24, 2007
495
richk
Jan 24, 2007
495
wear eye protection (nm)
richk
Jan 24, 2007
495
Dec 25, 2000
6,052
Easier, a putty knife or scraper worked best...
for me to remove the beast from the shaft then I use the green non-metallic abrasive scrubber pad to remove the residue and clean the shaft to make it sparkle. Terry
Dec 25, 2000
6,052
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
The very BEST...
...is TRACS. You simply spray it on and watch them disappear(NO elbow grease at all). Best of all its environmentally friendly stuff. Needs no special protection for you or the yard, completely biodegradable. From the manufacturer: Barnacle Buster™ is a safe, non-toxic and biodegradable marine growth remover specifically formulated to meet an industry wide need for fast, safe, cost effective alternatives to mechanical cleaning of seawater cooled equipment. With minimal dismantling required, Barnacle Buster™ can be safely re-circulated through seawater cooling systems, dissolving barnacles, zebra mussels, calcium, rust, lime & all other mineral deposits. Green Marine Products is now carrying Baracle Buster in our product line.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
The very BEST...
7,684
Alden 50 Sarasota, Florida
Barnacle Buster
sold under various trade names is industrial grade phosphoric acid. It works well. If you dilute it, be careful - remember what happens when you add water to acid and regardless of whether you dilute it, try to keep it away from the shaft log and strut bearing, both of which can be easily damaged by the acid.
7,684
Barnacle Buster
Feb 10, 2004
4,232
Hunter 40.5 Warwick, RI
The real problem area is inside the hull......
The hardest area to clean is the shaft where it disappears up into the hull. It is in a tube-like area. I have devised a simple tool that cleans this area easily. See the attached link to a Photo Forum posting that I made a while ago. Otherwise, I agree that a good scraper is best. I follow-up with the waterproof sandpaper that is available in rolls for cleaning copper pipes and clean the shaft with a wrap around it and a back-and-forth motion with the sanding strip.
Feb 10, 2004
4,232
V
Vic S
About your ZINC
One thing I read about everytime I added or replaced any Zink tab or add ons was that you should not have any paint or antifoul on them. They may not be as affective. This is something I always see being painted over.
V
Vic S
About your ZINC
