I bought the Garmin 546s GPS and also bought the Airmar P319 transducer. I currently have a like-sized (pretty sure) speed transducer in the hull that I intend to remove and replace with the 319.
Anyone out there have any hard earned wisdom on removing a transducer - if so I'd love to hear about it. Right now I intend to remove the tightening ring; perhaps stick a putty knife under the trim ring (outside hull) and pry a bit; and then take a pipe wrench back inside to try and loosen the transducer. Since I'm not sure how this was sealed (hopefully not with 5200) I may get some of that anti-bond, spray it on and let it soak a bit before I attempt to loosen. If all is right with the world it'll just fall out!
Again, any recommendations, comments, stories are appreciated.
Jim
Jim
