Hello Beneteau Owner
As I've written before, I recently bought a 2002 Beneteau 331.
The cabin-top starboard clutches are broken and difficult to use because they're old and improperly sized for the lines that run through them. They're Spinlocks, and, I suspect, original equipment.
My question today is "How should the headliner be removed and replaced?", which must be done to to replace the clutches.
It has 4 screws (covered by white plastic caps) at the corners of the hatch which clearly need to be removed. What are the other steps to remove and replace it?
A related question is "Is there a fairly comprehensive document or book that would answer this and similar questions about my boat, or Beneteau Oceanis boats in general?" The BENETEAU 331 OWNER’S MANUAL (attached) provides no guidance on the maintenance and repair of many areas of the boat, including this one.
Thanks in advance
Arthur
Thanks in advance
Arthur
