Remove DS10 Depth Sounder from Bulkhead
Feb 25, 2014
41
Hunter Hunter 30 Lake Lanier
I need to remove my DS10 from the bulkhead on my 92 Hunter 30. As I look at the back of the unit, there does not seem to be screws to keep it attached. I suspect Hunter glued it to the bulkhead. In case this is correct, what is the best way to remove the unit without causing damage to the fiberglass/gelcoat?
Thanks
Feb 21, 2013
3,782
Hunter 46 Point Richmond, CA
A photo of the back of the instrument might help to see if there is a ring that springs out or consider contacting the manufacturer (Standard Horizon?) for a manual.
Likes: ggrizzard
Feb 25, 2014
41
I hope to be at the boat, later this week. Will take a picture of the unit. Unfortunately, the manual is not in the Hunter Owners set of documents.
Thank You
Feb 25, 2014
41
I did download a manual, which states there is a ring that can be used to hold the unit in place. As I looked at mine, I was able to remove it. It was held in place by silicone. Spent more time scraping the old silicone off the gelcoat then removing the unit.
Wish Hunter spent a little more time and not cut corners in these areas.
Thanks,
