Remove cover on coarse/primary filter?
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi
all ready for new season, fuel & oil filters changed,
engine oil replaced,
UV sacrificial strip replaced on headsail
sails checked and patched.
But I cannot get the cover off the primary filter.
A local RNLI mechanic advised me not to bother - the fuel flow rate was
so low that provided I replaced the fine filter every year it "didn't
matter"..
Any comments?
John
V1447 Breakaway
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
Oct 19, 2019
921
Hi Steve
that message never got through.
Can you resend?
Thanks
John
V1447 Breakaway
Oct 31, 2019
163
...cannot get the cover off the primary filter...
That's the one on the back of the engine; yes?
Your friend may well be correct, I've opened up ours and cleaned it on several occassions and never found much crap in there, having said that I'm happier to have checked. It is a bit fiddly to get off, especially the first time I did it - stuck down with paint, which looked original so perhaps never previously done? Hints which might help: -
the cover doesn't 'overlap' the main body, so levering on what appears to be its projecting edge is a waste of time, the cover's edge is a 3-4mm in from the edge of the pump body.
If you remove the centre bolt completely, then press your thumb over the hole whilst someone turns the starter, the fuel flow pressure might 'lift' the cover for you.
Alternatively, find the edge of the cover (its not easy to discern) scrape around it with a sharp point - I use a sail needle, then gently tease it up with a strong needle.
Good Luck,
Bob Carlisle
Spring Fever 1776.
Nov 8, 2001
1,818
Hi all
A DVD of the IFR2008 is now available from the VAGB. It has been edited and Produced by Joop Wagenmakers of the Dutch Vega Club.
Professionally packaged and available, including postage UK, for the princely sum of £5. All profits will be donated to Vega Funds for the benefit of all Vega owners worldwide.
Contact me on steve@... for further details
Cheers SteveB
Oct 19, 2019
921
Thanks Bob.
As always, this list is a fantastic resource.
All the best
John
V 1447 Breakaway
Oct 30, 2019
234
Hi All
I have purchase copy of the DVD of the IFR 2008. It is a fine example of the ethos that keeps the Vega an active class of boat. Not only does the film cover in interesting detail with excellent photography the sailing and social events of the gathering but also demonstrates the love and dedication that Vega sailors have for their wonderful little boat. Thanks to Joop Wagenmakers for the time and effort that he has given to the films
production.
I am not on commission but recommend the purchasing of a copy by both the Vega owners that attended the IFR 2008 and those that could not be there.
David Wisdish
V3283 Ponteneur
Sent: Wednesday, January 28, 2009 6:12 PM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] DVD of IFR 2008 - Brilliant and professional
Hi all
Cheers SteveB
Nov 8, 2001
1,818
Hi David
Thanks for the endorsement. Joop Wagenmakers did a fine job. All profits go to teh benefit of Vega owners worldwide...
C\'mon you lot, dig deep only £5..... Payable via Paypal if you wish to steve@... (Please add £1 for USA/Canada to cover extra postage).
Cheers all
Steve B
