My wife and I took over ownership of her father's 1979 Hunter 27 after many years of lack of use (and lack of care!) last year. The boat was a disaster when we got it from him, and it still is, but I'm making it better every weekend.
Anyway, my most vexing problem right now is that the transmission oil fill cap (& dipstick) is hopelessly stuck in place. I have a new one, but I can't remove the old one - the 30-year-old plastic has gotten brittle and it's really stuck on there good.
The tabs along the top were broken down to nubs over the years, so they are no help. They were not tall enough anymore to get pliers on them.
I managed to get a pair of channel-lock pliers on the rim of the cap, and while I got the cap to turn for a second maybe 5 to 10 degrees, the plastic along the rim disintegrated in the jaws of the pliers, so there isn't enough structure to try that again, and of course you can't get pliers on another part of the cap due to interference, so I can't get at a "fresh" part of the rim.
Finally, getting desperate, I drilled two shallow, small-diameter holes into the top of the cap and stuck the tips of a splayed pair of needle-nose pliers into the holes and tried twisting it open that way, but it didn't budge. The pliers dredged their way through the mushy, degraded plastic. I thought I can try it again with the holes drilled further apart (and closer to the rim) for a bigger torque moment, but other than that, I am out of ideas!
Does anyone have any suggestions for how to get this blasted transmission oil fill cap off?
I will of course pump out the transmission oil afterward (and flush it a couple of times more after it gets in the water and I can run the engine) to make sure I don't have any bits of plastic left in there.
