i dont know what
kind of shape the gel coat is in because of the several layers of paint covering it not to mention the lack of prep work between layers the bottom paint is thick and was put on so with a roller (it shows) nice texture for a wall but not my boat.it doesn't glide through the water , it dragsi hope the same lack of care was taken when applying the first paint job so it wont damage the gel coat too much removing it alli'll probably use an epoxy primer then a couple of coats of awlgrip or the like to get the color i want and a glass finish p.s. the gel coat is the water tight epoxy seal that bonds with the existing fiberglass resin that protects from delamination and blisters its not just cosmetic
