Most of the cables for wheel steering are the 3300 series cables and knowing the lengths would help. One of the most frustrating jobs is running the new cable thru the wheel steering. If you take the rubber seals and nuts off both ends that is the first thing I would do. Then I would find a small tube long enough to go thru the wheel steering down thru or to the hole. Then I would insert the cable into the tube down to and thru the exit on the bottom of the wheel steering and then slide the tube back up and over the remaing cable and that saved alot of work. Hope this works for you all.
crazy dave
