Has anyone relocated the bilge thru-hull on an H31? Mine is on the starboard side of the boat and regularly douses the dock and my neighbor's boat with bilge water when I'm away. Because it's below the rail, it's also not really above the waterline when I sail in anything above 10 knots (which is pretty much everyday around here). I'd like to either relocate it, or rig some sort of diverter on the outside of the boat (for use only while docked) that will direct the flow of water down instead of straight out onto the dock. I can't think of any location to relocate the thru-hull that won't result in 15 feet of hose between the bilge pump and the outside of the boat.
