Re: Rejuvenating Interior Woodwork with Vinegar and Olive Oi
Plan,
Some folks like teak oil, others like varnish and, both work for the believers.
When I bought my C30, the interior wood was oiled, but not been re-oiled for some time before I took ownership. To clean the teak I found a product called, Snappy Teak; a two part stripper & cleaner. I tried other brands, but liked the look of unfinished teak I got from Snappy Teak. It was, for me easy to apply.
After my initial stripping & cleaning, I first used the teak oil, & it was like instant sex, the wood came up brilliantly. However, for the next two years & four applications later with oil, I decided I was unhappy with both the extra maintenance & the lack-luster look of oil over time.
So, I decided to re-strip the teak & apply a varnish coating as opposed to oil. The problem I found with oil was, that over a 4-6 month period, my wood would pick up dirt, dull & darkened soft wood pulp areas between the harder wood grains.
Oil is NOT a real sealant to your wood especially Teak plywood veneer wood such as bulkheads. Only varnish actually seals you wood from dirt, mildew & moisture. I know some will disagree with me on oil vs. varnish, but for the past 15 years now, I have no re-oiling or re-varnishing work to do. This cuts down on my maintenance time & material, allowing me more hours to concentrate on the more important issues, thus keeping my maintenance schedule current.
CR
