My '73 came equipped with a huge plastic folding ladder that connected to mounts deck mounts on the bow. It was brittle with age and required repeated improvisation to get swimmers out of the water last summer.
I have a new transom ladder I want to install but I have a question about reinforcing the mountings. Where I'd like to mount the ladder, there is a void between the transom fiberglass and and lazarette lining roughly between 3/16" and 1/2".
I know some transom jobs like the scuppers call for adding a piece of plywood between the fiberglass but I'm not sure I'll be able to access this section. I've considered trying to fill the are where the hardware will mount with thickened epoxy, or drilling the liner oversized and using a metal bushing/collar/spacer to make the area around the hardware solid, and then installing a backing plate.
Am I overthinking this? Would a couple of backing plates (2" wide 3/16" aluminum strips) inside the laz be enough to support the ladder? I want to overbuild this a little, my friends and I are big guys and I would hate to have the ladder damage the transom.
