When I hauled mt C30, it had a 1" crack in the front and a 1" crack in the back of the keel right at the joint. It could have been from me running aground on a sandbar while going to the yard, I don't know.
I bottom painted it 4 months or so ago. I widened the little cracks back into the keel until it wasn't cracked, and all I saw was clean uncracked fiberglass. I filled it with 5200 and painted over it. Now that I have messed around with fiberglass a bit, I am thinking of grinding out a 5" wide or wider band around the keel with the keel joint at the center and filling it back in with fiberglass and epoxy. I want to extend and thicken the area around the keel joint.
Is this an OK thing to do? Do I need to retorque the keel bolts at some point? How thick should I go to have a strong joint?
