Registration Numbers Removal
8
Catalina 22 Winthrop Harbor
I just purchased a used boat at I am in the process of changing the registration numbers. Any ideas as how to remove them easily. I tried peeling them and they don't peel. Any advise would be greatly be appreciated.
jimg
Jun 5, 2004
175
catalina 27 dana point
Removing numbers
Very simple. Use a hair dryer and they will come right off. A plastic scraper may be necessary. Use paint thinner or another solvent to clean up the adhesive residue. I have done this many times.
Jun 4, 2004
189
Catalina 30mkIII Elk Rapids, MI.
#'s
Hi Macklin; I just spent a morning replacing my shear stripe tape, same material as registration #'s. As the other poster advised, I used a small hair dryer and a single edge razor blade moving along behind the dryer on the warm tape. Use a very slight angle to avoid digging into the gelcoat. When the numbers are all off, use paint thinner or acetone to remove the left over glue. Then, I used a little 3M Finessit polish to "smooth out" the color difference where the letters shielded the gelcoat from the harsh effects of the sun. good luck Dave
Nov 12, 2006
256
Catalina 36 Bainbridge Island
When Using A Razor
blade, dull the side that is next to the hull. That will lower the chance of gouging the gel coat as you scrape. Just rub one side of the blade on an uneven metal surface to dull the edge, mark one side so you know which side has been dulled. It works! I helped a friend remove the cove stripe on his boat. No gouges on either side.
