#'s
Hi Macklin;I just spent a morning replacing my shear stripe tape, same material as registration #'s. As the other poster advised, I used a small hair dryer and a single edge razor blade moving along behind the dryer on the warm tape. Use a very slight angle to avoid digging into the gelcoat. When the numbers are all off, use paint thinner or acetone to remove the left over glue. Then, I used a little 3M Finessit polish to "smooth out" the color difference where the letters shielded the gelcoat from the harsh effects of the sun.good luckDave
