Regarding a 1987 ODay Sailor 1 17ft in Length.
Aug 23, 2023
1
Oday DAYSAILOR 1 Denver
I would like to know how the internal mechanism of the centerboard works. It is raised and lower via a lever on the side of the CB housing.
I bumped into the shore on a windy day and am not sure if it was damaged. It seems to raise and lower but does not raise all the way up into the CB housing. Is there a diagram somewhere showing the internal workings of the CB? Thanks so much.
Mar 20, 2004
1,753
the DS 1 doesn't have a mechanism - the pivot on the lever handle just goes into a square cutout in the board. It's possible you have something jammed in the slot, or you fractured the leading edge of the board so it doesn't fit any more
