Refrigerator TOO cold
14
Hunter Vision-32 Puerto Vallarta MX
I have an ice box in my Hunter Vision 32 that I converted to a refrigerator with a Nova Kool compressor/ plate kit. It has worked great for 2 years. Now it freezes everything in it although I have set it on the lowest setting (1). Anybody have any ideas on what the problem might be ? Thanks Richard Stanley
Jack
Reefer too cold
You should check your thermostat first. If it is ok, the problem is that you are just a "little bit" low on refrigerant. When you have just a little shortage of r134a or r12, the evaporator plate will have too much boil area. Freon boils at -33degrees. I know it sounds complicated, but have a qualified tech check your freon levels. The settings on my Adler unit are 6lbs on the low side. Best of luck, Jack
Mar 30, 2006
14
Thanks
Thanks Jack, I did a little research and discovered that I did NOT install the thermostat properly. I did not conect the "temp guage" wire TO the cold plates. I hope that will do the trick. Richard
