Refrigerator drain?
Ted B
Can anyone tell me where the drain on the refridgerator on a C320, 1999 goes. The fridge is holding water, I tried to snake thru the clog but no luck. Wondering if I'm hitting a seacock. Any advice is really appreciated.
F
Frank Gazzano
Valve
I can tell you that on the 310 there is a 3 way valve under the sink that controls the fridge drain. The purpose for keeping it closed is to prevent cold air from leaking out but you need to remember to open it if you're cleaning up inside.
RG Miller
1995 C320
I've got the 95 C320 and the drain runs down a hose into the bilge. There is no valve or anything on mine. When you open the board over the bilge pump you can see the hose draining into the bilge right there. One hose comes from behind the motor and the other is from the cooler. Hope that helps.
Bill Doyle - S/V Calico Dragon
Hope This Helps
I've got a 2000 Catalina 320 and my set-up is that the fridge drain is coupled with the shower. What you need to do is power the shower drain at the c/b panel and then push the shower drain switch in the head. If the sink doesn't drain (or you already know that you are in the drain the shower mode) then under the sink in the head there is a "Y" valve. Turn it to the opposite position and try the shower drain switch in the head again. If that doesn't work then your arrangement is different than mine. Good luck. Bill
Ted
Thanks for the help
Thanks, the fridge/shower drain valve did the trick!
