Also Adler Barbour
Sharkey,I installed the Adler Barbour Cold Machine in my 1987 C36 6 years ago, and have been extremely pleased with it. It uses 3-4 AH on average, and has required no service. I added an extra 2" of foil backed foam insulation around the outside of the box, put 2 cans of "Great Stuff" expandable foam between the box and the hull, and added weatherstripping to the edges of the lid. The compressor mounts nicely in the area behind the box, to the port of the aft berth. The cockpit locker had too little ventilation and I didn't want the compressor to get beat up by the gear stored there. If you suscribe to "Mainsheet", you can get back copies of the Tech Tips from Bob McCullough. I wrote a long article describing the process back at that time. Good Luck!Tom Soko
