Refrigeration systems?
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
It is called a cold plate it is filled with a solution that gets extremely cold and stays cold it's adaptable to any other condensing unit within the same BTU range
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
Thanks! The compressor seems to be set up to cycle to keep the plate between -5 and zero degrees C. Wondering if there is any possibility of creating a freezer compartment using this system.
Sure there is.
Looks like it is cooling.
You’ll need to learn about the process and assemble all the parts.
