Refrig drain
1
- - Tampa FL
I just purchase a 1999 352 and have a problem with the refrig drain. It doesn't drain and I have tried to find where it is supposed to drain.. I have tried the shower sump and turned on the bilgle but still nothing and it doesn't have a connection to the sink drain. Any help would be appreciated.
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Look for a switch in the vicinity of the fridge. If I recall correctly on the 361 it was on the cabinet on the right hand side of the oven. The 352 might be the same. Once you find it just push the button to make the pump run.
Jun 4, 2004
287
Beneteau Oceanis 352 NYC
There is a red handle down by the bilge pump, on position drains the bilge when rotated, it will drain the fridge.
May 24, 2007
185
Beneteau 352 Milwaukee, WI
If you have the owners manual ... check page 54, paragraph 13.5.3.2 Pump House Layout. It shows a picture of the pump/valve layout under the starboard seat. There is a "Y" valve that lets you use the electric bilge pump to either pull water from the bilge or drain the fridge.
Took us a while to figure this out too after we took delivery of our `99 352.
Sep 4, 2010
51
Beneteau Mooring 352 PUERTO LA CRUZ
I have a similar boat. You have to turn on the switch braker in the panel that says bilge pump but first you have to go in under the seat in the dinner in the starboard side and turn a "Y" valve (two way valve) one side to the bilge and the other side to the refrigarator drain, so turns the valve to the refrigarator pump side and once you switch on in the electric panel you will hear the water going in to the pipe inside the refrigarator. In the owners manuel you can see where is the Y valve.
