refinishing the wood and fiberglass
P
Pat
1. I need a product to refinish my wood something that will last a long time I have sanded down all the wood and it is ready for a new coating that will last the last varnish coat only laster 1/2 a year 2. I am looking for a product to give my old fiber glass look shiney and new I am in the prossess of cleaning all the I bottom groth off the boat and and would like to recoat it with something to give my boat some new life Pat skysurfparasail@yahoo.com
1,077
Several Catalinas C25/C320 USA
Cetol
Cetol is the way to go for exterior wood. Clean the teak (anyway you want to) put on three coats of Cetol and you are good for at least two years.
A
agolden
Refinishing
First, put down at least 2 coats of sealer. then apply the varnish. I did this project this spring and used a product from the Ultimate Cabin Sole Company. They have a new product for exterior teak. After stripping off all the old varnish (gel stripper and heat gun) I applied the sealer - wet sanded with 220 - used mineral spirits to clean off the teak - then applied 2 coats of the varnish. I again wet sanded with 220 and applied 2 more coats. Not only does it look like new, it has not showed any signs of wear since April when I did the work (I am on the Chesepeake Bay). I have included the link to web site.
Jul 15, 2005
23
Catalina 30 Fort Myers, FL
Fiberglas restoring
Pat, I've owned old boats for years. I've never come across a product for restoring fiberglass that works as well as Poly Glow. I've used it for the 3rd time on my 1989 Cat 30--that was not maintained well before I purchased it--and I always get asked if I've just had the hull awlgripped. Check it out in Practical Sailor. It's very easy to apply if you follow the directions. They have a web site.
