Gerry, were you my guardian Angel telling me what
to do? Great advice! But then you're a pro.
Two things to add. Well, maybe more. The first is to insure all of your stainless parts do not touch aluminum after the rig is reassembled. OK, maybe that's last. For prep work I ground out all of the corrosion prior to metal-prep. Then I filled the corrosion with MarineTex. Then block sanded to a level surface. Just like painting a car. Primer and sand. Just a second, I'll check the can,,,
I used U.S. paint epoxy primer. It goes on thick with lots of brush marks. No problem. Wet sand it with a hand block, 220 grit or so. Yes, wet. You won't get six inches to a sheet of paper if you don't. (I tried) Let's see, I used the spray etching primer from ??? I don't remember. It's yellow and goes over the bare aluminum spots that the epoxy primer/filler is not suited for. It is very thin when dry. When I was a Navy Yard painter in the '60s, we called it 117 primer. OK, all of your flaws are gone by this time. Mix up your paint. I used Awlgrip linear polyurethane. It's two part. Mix up a bunch and apply with a roller. Be ready to mix more right away when you run out so that no lap marks have time to form. I mixed a pint or so at a time.I found very dense foam rollers at Home Depot. They are made of thick sponge like material and really hold a lot of paint. They are also small diameter. Load up and paint. Look over your shoulder at the paint you just applied. When you see the paint bubbling, go back and tip. Use the same roller but with no extra paint. (damp) Caution! On a sunny day the shine will hurt your eyes. I used white of course but it's your call.On my web site, photo's #88, 100, 126 and 128 among others show the shine. I did the spinnaker pole too. The black end caps are appliance black epoxy spray can paint also from Home Depot. The job took about a week. All paint should be applied when the temperature reaches 70 degrees or so. And make sure the last of it goes on no later than noonish. Two coats will do it. One per day per side. If evening condensation occurs it will dull the finish if you paint late. No big deal, just do it over. But boat-yards cost money. Even more if you need a covered enclosure. Good luck Rick. This is one job worth the effort on any age boat. Sorry Jon.
I'm going to cut and paste this to my web site too. The paint job description got lost in the shuffle.P.S. This edited text is now on my web site under photo #100 just is case it's useful to anyone.
