The finish on the teak veneer plywood port and starboard of the companionway has deteriorated. See photos. The PO tried to refinish the area with varnish which made it worse. In the Hunter Owner's Manual it recommends 330 grit sandpaper and then a Mohawk filler and shellac topcoat. This worked very well on the owner stateroom door which was in good shape. It allows you to just match in a part without stripping the whole thing. I tried it on the salon table but wound up having to strip the top starting with 80 grit on a random orbital and then 7 coats of Epifanes which to look good was wet sanded with 2000 then buffed. See photo. The factory finish on the table was very hard, thus the 80 grit. I have thought of sandpaper, heat gun and maybe a paint stripper. Any suggestions as to preparation and then finish. I can't be the only one out there with this problem. Help! Does anyone know what the original finish is on the teak veneer. It seems very near to the filler and shellac from Mohawk.
