It doesn't have sufficient corrosion to affect the mechanical integrity, it just has some surface, white, aluminum oxide where the black finish has failed.I assume it's a aluminum prop? If so and it has some corrosion I would recommend replace it.
The aluminum oxide will protect the underlying aluminum. Keeping paint on a prop is a losing battle. The props action through the water will wear away the paint. Looks good in a show room though.It doesn't have sufficient corrosion to affect the mechanical integrity, it just has some surface, white, aluminum oxide where the black finish has failed.
That's a good point. I have one of these props that has the paint worn off the blades and in use it retains a nice, dull-gray patina.The aluminum oxide will protect the underlying aluminum. Keeping paint on a prop is a losing battle. The props action through the water will wear away the paint. Looks good in a show room though.
You are right about anodize. But consider the cost and time to find a shop to strip then another to anodize, you could just by a new one. I believe that jviss is referring to a small HP prop for his dink.aluminum should be anodized to prevent corrosion. Anodize makes a pretty good surface to paint, but if it was bare aluminum and only painted then it will corrode. A plating shop can maybe strip the paint and re-anodize it for you. Not an expensive process. Another option is to use conversion coat (tradename Alodine) that also provides corrosion protection but not as good as anodize. This can be done at home if you buy the Alodine. Amazon.com: Henkel - Alodine 1201 Light Metals Conversion Coating, Quart: Gateway
