Rob Anderson
We have a new 306 with a "classic" main (ie not roller furling)and for the first time this weekend wanted to reef the main. Should have checked this out at delivery but to my surprise there are no hooks on the boom or mast(as was the case on my previous boat) on which to secure the rings for the two reef points at the tack of the main. Are you supposed to undo the shackle at the tack and attach the ring there ??? That seems a bad situation ...typically when you reef the seas are not calm and I started with this avenue and gave up. Also thought maybe you could put the ring around the outhaul lever. Ended up not reefing and the winds moderated.Anyone out there have an answer to this ?
