On my boat the reefing lines are the same aft, but forward each line comes out of the boom, goes through a turning block on the mast and up through the forward reefing cringle then down through a block at the base of the mast, then through a turning block and aft to the cockpit where they are secured by a clutch.
The reefing lines aren't run back in some of the photos, but are white/green fleck :cry: and white/red fleck
. You can at least see the arrangement of turning blocks. On the starboard side three lines go aft, reefing, main halyard and the spinnaker halyard. On the left, just two. The jib halyard and the reefing line. In the third photo you can see the white/green fleck reefing line come down from the cringle (the sail is furled so use your imagination) and through...this is ridiculous...I found another photo...look at the last photo and you can see the line coming down from the cringle to the block.
This would be a worthwhile improvement to your boat, especially if you will single hand on extended trips where you might not anticipate the need to reef.
