C-42 2nd Reef works very well
Hi, Dan--Some good response to your post. I've done it and like it.The 2nd reef was easy to to install. My stock sail already had the cringles and points for a 2nd reef. All that was needed was the butterfly (double bullet) block. Catalina sent one. It's a two-line system. The lines are rove just like the 1st reef, but the opposite way and lead to the cockpit on the opposite side (port). It takes a bit of trial and error to get the aft reef line correct. With the sail raised, the line should pass around the boom (directly beneath the 2nd reef cringle) and back through a cringle in the foot of the sail with a small bowline about the standing part of the reefline, up through the 2nd reef cringle, down to the sheeve at the boom end, into the boom, around the aft sheeve of the bullet blocks with the block just short of the aft end of the boom, to the dead-eye at the boom end. The fwd reef line goes from a dead-eye at the mast at one side of the gooseneck, through the 2nd reef cringle, around one sheeve at the fwd end of the boom and around the fwd sheeve of the bullet block, back to another sheeve at the gooseneck, around a turning block at the mast collar, through the line organizer to the jam cleat in the cockpit. Works just like the 1st reef lines. I made the mistake of using a double block at the mast collar for turning both 1st and 2nd reef lines. Two separate blocks are better.One thing important! I found that with the slide-stop in place at the keyway, the sail could not be lowered sufficiently and undue stress (to the point of ripping) was placed on the sail by the 2nd reef line. What is needed is a MAST GATE. If you have a Charlston spar, send them a "rubbing" of the keyway and they will send you an appropirate pair of gates that screw in place over the the track keyway to allow the sail to drop to the boom without spilling out the keyway.They are adjustable, retracting out of the way to remove the slides when its time to remove the sail. The original slide-stop now parks out of the way down by the gooseneck.With the mast gate, the system works like a charm. Seldom have I had to worry about being overpowered and that includes sailing in a full gale.Cheers--Ernie April(WindCatcher C-42 #618)
