Bill and Tim, I hope this file comes through showing the reefing system. Thanks, Ron
I looked at your diagram, and it is very clear and easy to understand. While I wonder about how effecively you can pull the tack down and forward, I suspect that those eyes on the mast do a good job, especially in light of the single tack line.Bill and Tim, I hope this file comes through showing the reefing system. Thanks, Ron
Bill,The full up boom would require three sheaves on the boom end (reef 1, reef 2, outhaul) and 3 at the gooseneck (reef 1, reef 2 outhaul). the cunningham can be rigged directly to the mast base. Presumably the outhaul would already have a boom end block so you could just place 2 cheek blocks there to handle the reef lines. The gooseneck could also get 2 external cheek blocks for the reefs. That just leaves the outhaul gooseneck to mast turning block to figure out. Kinda depends on how the OEM handled the outhaul at the boom end.
How is your outhaul handled at the boom end? Internal or external line?
