Reefing line
265
- - Milwaukee
Tips on running a new reefing line through the boom? I assume I can snake it, or maybe I'll have to take off an end cap. The old line popped this summer, for reasons I still can't quite explain. I was surprised at how brittle some of the line was, however, after 5 yrs. It's normally under the sail cover, but it was though it was sun-dried. This is on an H356 with standard main.
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
Start small
Paul, The caps are usually rivited on. Use a fishing line with a weight. Disconnect the boom and tilt it up so you slide the weight down the length. Use the fishing line to pull your new line through.
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
Weed Wack Line
It is much thicker than the fishing line so it goes straight but yet it still bends to go around curves.
